Re: Ricoh SG3110DN printing from Photoshop
Posted: 29 Jul 2020, 09:51
by Volusian
Hi all ... i have upgraded and reformatted my PC again. I have been using Sawgrass powerdriver v4 but every time i upgrade the PC i have to contact Sawgrass for an activation code for Powerdriver. I now use refillable sublimation inks and want to be able to print direct from Photoshop CC using the Ricoh driver instead of the Powerdriver. What do i need to do to get the Ricoh driver to print accurately ... any help appreciated .. thanks
Posted: 29 Jul 2020, 10:08
by raydavies
The supplier of the ink should have the ICC you need.
Ray
Posted: 29 Jul 2020, 10:12
by DS Designs
I went down this route a year or so ago, and changed inks from Sawgrass to Subli sharp inks and refillable cartridges in my Ricoh 3110 from Inkexpress. They supply an ICC profile which you install into photoshop. Easy as pie. So basically you would need to get hold of (or get made) an ICC profile for your inks and your chosen paper combo, install into photoshop and job done. Good luck
Dave
Posted: 29 Jul 2020, 11:20
by webtrekker
Once you've installed the ICC you need to set Photoshop's print manager to 'Photoshop manages colors ...' and select your ICC from the dropdown list.
Set your Ricoh printer driver to plain paper, high quality, color profile:off.
