Opinions on this heat press PLEASE
emt
Re: Opinions on this heat press PLEASE
Post by emt »
Hi, I’m thinking of getting this heat press but I have no idea if it’s any good or not? Can I please have opinions?
https://www.thetransferpress.co.uk/a4-m ... 2x30584625
It all depends on what you want to do and how much you want to do.
Will it work... yes probably
Will it last... I doubt it
Will I want bigger and better within a month or so... almost certainly
If you just want to do a couple of things a week then this will be adequate, if however you are looking to being a bit more "serious" then I would look for a better quality machine at around £500+
emt
Post by emt »
Thanks for replying, decided to go for it in the end. Spoke to someone from there and he said he believes these were made by Adkins for a company that went into liquidation a while ago?
Looks like a cheap generic Chinese press, nothing like an Adkins
emt
Post by emt »
Oh brilliant!
is there any way of identifying it, any tell take signs? It’s due to be delivered tomorrow.
must admit I searched to try and compare it to others and it looks very similar to a lot of the 5 in 1’s etc but without all the extras?
i was told he “believed” it to be the version down from this
https://www.heatpressesdirect.com/swing ... ure-sensor
raydavies
Post by raydavies »
Adkins do have machines made in China to their specification and they are indeed sold bt The Transfer Press. I have a mug press from there and (so far) it has been great.
Ray
emt
Post by emt »
Thanks that’s good to hear ����
It’s just arrived, says on box Made in China and also that’s its a 6 in 1 but then on a separate sticker says press only. I thought it looked like the multi press ones.
Theres also a sticker on the box that says Cadet Swing?
search AliBaba for Cadet swing heat press would be your starting point I guess
