Re: Paper coming out slightly skewed - SG400
Posted: 28 May 2020, 16:45
by MikeJB
My SG400 has recently started printing out my papers (I use pre-cut mug papers mostly) a little skewed. No amount of loading/reloading, adjusting or wiggling seems to help. Does anyone have a clue what might be causing this?
It's not a showstopper as even with the slight skewing the images are fitting onto the papers (just) but I want to fix this asap in case it decides to get worse.
Posted: 29 May 2020, 17:52
by Mrteajunkie
I don’t use that printer sorry but someone else here might?
Posted: 31 May 2020, 20:34
by Nuttylad
I'm having the same issue with the SG-400, I thought it was the cheap paper cutter I had got, but got a better one and realised it was the printer. I use just A4 paper and its the same. So would be handy to know if there is a reason for it.
Posted: 31 May 2020, 20:39
by UK Printed Mugs
2nd that. We use mug paper but always guillotine after printing. 400 is now superseded by 500 so perhaps if anyone has one then be good to know if it handles paper better
https://www.novachrome.co.uk/equipment/ ... idges.html
Posted: 31 May 2020, 20:44
by MikeJB
I've contacted Sawgrass and I'm waiting for a reply. If I get any info I'll post it here.
Posted: 31 May 2020, 20:56
by UK Printed Mugs
Apparently SG500 has one roller now whereas SG400 had two which i presume could be cause of paper misalignment. I guess they knew this issue.
Posted: 31 May 2020, 20:59
by SweetPea
Ive seen this video about it on Heatpress nation. Maybe it can help:
https://youtu.be/RJlgCszW7_s
Posted: 01 Jun 2020, 22:38
by MikeJB
Thanks, SweetPea. The reply I just received from Sawgrass gives a similar suggestion to the video you linked to:
Thank you for contacting Sawgrass Technical Support.
Please use the link below to help you with your printing issue/concern.
https://printers.support.sawgrassink.co ... ut-skewed-
Should you need further assistance, please do not hesitate to contact us again.
Posted: 09 Jun 2020, 20:04
by SweetPea
My pleasure Mike. Happy I was able to ‘help’ at least a tiny bit (even being a newbie myself). [emoji4] [emoji4]
