Page 1 of 2
Re: Pigment ink for heat transfers onto cotton
Posted: 19 May 2020, 11:00
by SubOnCotton
Hi all.
I'm having a bit of trouble figuring out where to find some good pigment ink.
I've settled on an Epson 7210 with a CIS, because I don't think the Ecotanks can use pigment ink.
The Americans have it easy because they have Cobra Inks, but over here it doesn't seem to be so easy to sort out.
I've encountered this:
http://www.inkforinkjet.co.uk/shop/t-ch ... n-desktop/
... but the website is awful, which doesn't inspire confidence.
Then this:
http://www.inktec-uk.co.uk/inkjet_ink.htm
.... but again, a confusing website which reminds me of GeoCities.
Does anyone know of non-Chinese pigment ink for heat transfers onto cotton?
Posted: 19 May 2020, 11:08
by webtrekker
Try here:
https://www.cityinkexpress.co.uk/cheap- ... rce-series and skip down to the Pigment Inks selection.
I've use CIE (sublimation) inks for a number of years and they are a decent company to deal with.
Posted: 19 May 2020, 12:00
by SubOnCotton
I had a look at them, but I think their Fotorite pigment ink is Chinesy.
Posted: 19 May 2020, 12:16
by raydavies
I use his inks all the time and find them to be the best I've used. He (Ken) is very helpful.
Ray
Posted: 19 May 2020, 13:05
by SubOnCotton
Are you using an Epson for pigment heat transfers?
Posted: 19 May 2020, 13:10
by raydavies
Sorry, I was a bit misleading, I use his sublimation inks. I use my Cannon printers fo tees with dye based ink and papers from PPD - had no problems with fading.
Ray
by Mrteajunkie
I’m intrigued what’s pigment ink for?
How do you use it?
Posted: 19 May 2020, 13:24
by SubOnCotton
raydavies;143243 wrote:Sorry, I was a bit misleading, I use his sublimation inks. I use my Cannon printers fo tees with dye based ink and papers from PPD - had no problems with fading.
Ray
Crikey O'Reilly - now I'm getting confused
I thought that dye wasn't suitable for cotton because it's water-soluble and therefore will wash out and run.
Posted: 20 May 2020, 14:05
by GoonerGary
SubOnCotton;143235 wrote:Hi all.
Then this:
You found the Windows 95 version. Here's the up to date one.
https://www.inktec-europe.com/
They do good pigment inks, but finding the right one for your printer will be tricky.
Posted: 20 May 2020, 15:01
by SubOnCotton
GoonerGary;143265 wrote:You found the Windows 95 version. Here's the up to date one.
I think it's two separate businesses, with one based in Scotland and the other in Oxfordshire.
Contacted the former and no answer yet, so will contact the latter.
Thanks for the info.
