Need a source for 1mm thick aluminium bracelets
Help in finding new products.
Dollshousegirl
Re: Need a source for 1mm thick aluminium bracelets
Post by Dollshousegirl »
Does anybody know of a source of aluminium bracelet blanks with these measurements and rounded corners
I currently use a blank that is .75mm I could do with the metal being 1mm as that seems to add more weight and more value to the bracelet when its shaped
im looking for the measurements of thickness 1mm, 165.5x18.9 and d
1mm, 165.5x34.9
Sublimetals sell 1.1mm thick bracelets but not in the exact sizes you require...
https://www.sublimetals.co.uk/?s=Bracel ... mage26.y=0
Chromaluxe sheeting is cheapest from Novachrome - I think the 60x40 sheets work out cheapest per square metre, and then you just need metal guillotine to cut the strips, corner cutter, or sander/grinder wheel for rounding corners, buffing blocks for sanding edges etc.
Dollshousegirl
Thank you - perfect, I can work with these sizes
