Page 1 of 2
Re: Help! Ricoh printer not getting colours correct
Posted: 17 Jun 2019, 11:31
by Chrizdene
I have a Ricoh Aficio SG 3110DN printer and I am struggluing to get the colours correct. Everythiing is coming out too dark.Also not too sure if I have the correct sublimation print setting. HOw can I check this please??
Posted: 17 Jun 2019, 12:13
by webtrekker
Do you have an ICC profile installed?
What software are you printing from?
Posted: 17 Jun 2019, 19:13
by Chrizdene
webtrekker;138739 wrote:Do you have an ICC profile installed?
We are using Corel Draw.
We tried to download ICC but couldnt get it to load - any better sites to download from????
Also we cant get it to print directly from Corel Draw we have to save to PDF and print from there
We are also using after market refillable print cartridges are not being recognised by printer - (2 are and 2 not) - Im thinking it maybe the chip on the cartridge
Posted: 18 Jun 2019, 00:07
by webtrekker
Seems you have multiple issues here.
First of all, only use inks from a reputable supplier who will also supply you with the correct ICC profile for their inks which will at least put you in the correct ball park regarding colours.
I don't use Coreldraw, just Photoshop, but the process is basically the same. You must set your graphics software to manage colours (via the installed ICC), and set your Ricoh printer driver to NOT manage colours.
Incidentally, what items have you tried printing onto? Mugs? T-shirts? The print from your printer will always be way off colour, you need to press the print to reveal the actual colours.
Posted: 18 Jun 2019, 07:43
by mrs maggot
I create most of my templates in Corel, and then export to PDF as I have found it better to print from a PDF, but I do not do photo's so I find it works for me on lettering/cartoons fine. As webtrekker says, until you have pressed, colours on the paper look nothing like they do when they are printed.
Posted: 18 Jun 2019, 11:01
by pw66
What colour space are you using?
Although it sounds counter intuitive your printer works in RGB not CMYK. Make sure that Corel is set to RGB.
Posted: 18 Jun 2019, 17:50
by Chrizdene
Thanks for your reply. We are just setting up so havent actually printed anything yet - but are aware that the colours are off. We are about to order new ink so will ask for ICC then
Posted: 18 Jun 2019, 20:27
by Quinsfan
How can you know if colours are off if you haven’t printed anything?
Posted: 18 Jun 2019, 22:54
by Mrteajunkie
Quinsfan;138778 wrote:How can you know if colours are off if you haven’t printed anything?
The colours are dark but nothing has been printed yet.
I’m assuming they mean nothing has been pressed yet?
I would press something to test, the colours on paper are nothing like the pressed result!
Posted: 21 Jun 2019, 09:55
by mrs maggot
Did you load the inks that came with the printer ?
Are they dye sub inks?
If you have loaded the inks that came and they are not dye sub inks then you have to clean the printer right through, you cannot mix the inks.
