Any tips for UV primer for metal and glass ?
Re: Any tips for UV primer for metal and glass ?
Ive bought a Mimaki 3042 FX uv ..configured to cmykww ..so primer need to be added manually ..any tips where to buy and stuff ??
Andysam26467
Hi Ravi,Ravisteam;134380 wrote:Ive bought a Mimaki 3042 FX uv ..configured to cmykww ..so primer need to be added manually ..any tips where to buy and stuff ??
I’m not sure how to use primer manually. I use primer on most substrates as I find it helps bond the ink better and avoids scratching off. As a rule I use 60% primer set to valid pixels
Ricky@Xpres
Hello Ravi
This is a link to the Mimaki Primer https://www.xpres.co.uk/p-8771-sign-dig ... xpres.aspx
Just apply to the product with a lint free cloth and print the product within 24 hours.
Ricky
Xpres
Ricky
Xpres
- Has thanked: 13 times
- Been thanked: 12 times
Out of stock Ricky
Are you able to notify OP when this will be available again please?
Ricky@Xpres
Hi Justin
If you place an order for it today i can get it shipped direct from Hybrid for an extra £12.95 as they have stock.
Ricky
Xpres
Ricky
Xpres
Justin;134407 wrote:Out of stock RickyAre you able to notify OP when this will be available again please?
Thanks for the link Ricky ...When do u get the stocks ?.Ricky@Xpres;134406 wrote:Hello Ravi
Thanks Ricky ...
Ricky
Xpres
