Page 1 of 2
Re: Glass worktop protectors
Posted: 28 Sep 2018, 10:16
by RuthWinchester
Hi lovely peeps
Does anyone know where I can get 30cm x 40cm sublimation glass worktop protectors (preferably flat rather than chinchilla finish but not desperately bothered). Currently buying smaller ones from BMS but just been asked for the larger versions.
Any suggestions gratefully received.
Ruth
Posted: 28 Sep 2018, 11:32
by GoonerGary
Not exactly what you are looking for, but you could maybe contact the manufacturer and see if they do a version without the holes.
https://www.thetransferpress.co.uk/lume ... 2x17166167
Posted: 28 Sep 2018, 19:42
by UK Printed Mugs
If these are to be resale products then using a glass photo panel is NOT suitable as they won’t be toughened to withstand worktop use such as cutting on so could break easily. If you can go a little smaller and only have A3 printer then these are your best bet
https://sublitrade.com/products/28-5-x- ... oard-10pcs
Posted: 28 Sep 2018, 20:29
by pisquee
would they not need to be toughened to cope with the heat and pressure of going through a heat press?
Posted: 28 Sep 2018, 20:42
by UK Printed Mugs
Chopping boards will be tempered to ensure they don’t splinter if smashed but it is doubtful that glass photo panels would be.
Posted: 29 Sep 2018, 11:22
by GoonerGary
Glass coasters which cost £1-2 are tempered. I tried hunting down the manufacturer to find out if there's any more information, but couldn't find them.
Posted: 13 Aug 2019, 10:55
by GoldRapt
RuthWinchester;134354 wrote:Hi lovely peeps
Ruth
Ruth, Dis you manage to source a supply in the end, if so could you share please?
TIA
Posted: 13 Aug 2019, 11:06
by UK Printed Mugs
Xpres - Chinchilla. Longforte - Clear, SublimationDirect - Both
Posted: 13 Aug 2019, 11:28
by GoldRapt
UK Printed Mugs;139497 wrote:Xpres - Chinchilla. Longforte - Clear, SublimationDirect - Both
Thanks for the pointer. I cant find both on sublimation direct which is a shame and longeforte do what I want but in the wrong size. (im after 30cm round)
Chinchilla effect, If i understand correctly gives the printed image a fafed effect. Does anyone know of that is still the case and if it is, is there a way of backing up to improve the image please?
Posted: 13 Aug 2019, 11:50
by UK Printed Mugs
