Re: Anyone recognise this blanket?
Posted: 21 Jun 2018, 16:05
by socialgiraffe
Hi All
Anyone recognise this heat press blanket?
I know its is not a Genie 1 from LW
vB_ID:5309
vB_ID:5309
Posted: 21 Jun 2018, 20:02
by DyeSubSupplies
Looks like a best sub one simon, I will double check for you tomorrow
[QUOTE=socialgiraffe;132773]Hi All
I know its is not a Genie 1 from [/QUOTE]
Posted: 22 Jun 2018, 18:44
by bms
DyeSubSupplies;132776 wrote:Looks like a best sub one simon, I will double check for you tomorrow
From the photo and the 5 pin connector it does look like a BestSub heat blanket.
Posted: 25 Jun 2018, 12:10
by socialgiraffe
Cheers guys, only problem there then is how I came about having it as I don't remember buying it LOL!!!
Will it fit a DF1?
Posted: 26 Jun 2018, 06:43
by bms
socialgiraffe;132805 wrote:Cheers guys, only problem there then is how I came about having it as I don't remember buying it LOL!!!
Will it fit a DF1?
Yes assuming you have the 5 pin connector on the control box. Newer models of the DF1 will be 5 pin connectors as the control box changed around 3 years ago.
