Hi and sorry if this is in the wrong section.
I'm a complete novice to this but would like to print onto ceramic cups and also nylon bags. My question is what printer do you recommend for a novice start up? Thanks.
Sent from my SM-A310F using Tapatalk
Which printer?
- UK Printed Mugs
Re: Which printer?
Maybe something like this:
http://www.listawoodtradesupplies.com/i ... TAR&pgnum=
Re: Which printer?
Thanks but it's just a printer I'm after really. A cheap one too. [emoji6]UK Printed Mugs;131418 wrote:Maybe something like this:
Customprintwales
Re: Which printer?
Go with a cheap Epsom printer to start with. Keep away from the WF series and look at the XP photo printer series. You can get a cheap A4 one for under £50 and a cheap A3 for about £100
Then you need to at least buy refillable cartridges - about £20 for a set of decent ones. And small 100ml sublimation ink set at about £25 for a reasonable cheap ink
Don't go for super cheap sublimation ink as they can damage the printer head if the ink hasn't been finely filtered before bottling.
So for A4 set up you should have a printer set up for about £100
Re: Which printer?
Thanks for your help. I've got no idea on any of this but want to give it a go.Customprintwales;131420 wrote:Go with a cheap Epsom printer to start with. Keep away from the WF series and look at the XP photo printer series. You can get a cheap A4 one for under £50 and a cheap A3 for about £100
Any recommendations.. for the printer and ink supplier?Thanks
