Page 1 of 2
Re: How Do You Price Decals?
Posted: 08 Apr 2018, 17:35
by Stitch Up
I have no idea how to price up full colour contour cut decals of varying sizes!
Do any of you guys have any solutions for working out what they could retail at?
I just spent a few enjoyable hours creating accurate cutlines and the final decal looks brilliant :) Measures 14.5 cms wide by 8cms high.
Any ideas?
Cheers
John
Posted: 08 Apr 2018, 18:27
by Quinsfan
How many colours? How long on the computer designing it? How long to weed it all out? How much wasted material per decal? How much per meter has the vinyl cost you? Application tape also costs and people often forget that part. Also if you are selling on for someone to install themselves are you going to provide a squeegee.
Posted: 08 Apr 2018, 18:52
by Stitch Up
After posting I realised I should have include more info :)
The decals are printed on a Roland BN-20 so full colour.
The artwork was complex but all I had to do was create the cutline - took me about an hour to do accurately.
Print time is about 14 minutes for 3 decals 14.5 cms wide by 8cms high.
Weeding was a breeze and took less than a minute :)
The customer will fit so I guess I could provide the necessary and make a small profit on that :)
Postage would likely be one of those card backed envelopes.
Cheers
John
Posted: 08 Apr 2018, 18:56
by Quinsfan
In that case I would just work out the cost per meter of materials, ink is such a small cost that it doesn’t really factor. Are these going to be laminated decals as that may affect your costs. I print on a CJV 30-60 which I generally charge from £25 per meter I always laminate as standard.
Posted: 08 Apr 2018, 21:20
by Stitch Up
Thanks,
I don't laminate mainly because I never have and don't have any laminating equipment - would I need additional equipment to laminate small'ish decals or does the liquid laminate work well?
Cheers
Posted: 09 Apr 2018, 05:12
by Quinsfan
I apply the laminate file using the wet method and a squeegee then put it back through the machine to cut it.
Posted: 10 Apr 2018, 06:44
by Stitch Up
Thanks for the info, something new for me to try :)
Posted: 11 Apr 2018, 16:48
by logobear
you didn't use much media, but did use a lot of YOU !
QUOTE
"all I had to do was create the cutline - took me about an hour to do accurately."
An hour is a long time to create a cut line .....
Probably by the time you have done all the bits and bobs and addressed an envelope, and checked this forum a couple of times you will be upto 2 hours.
What is your shop target income per hour per employee?
The media and ink cost is negligable, but you have used a lot of you, your shop, and your £4000 machine ........
Shame you are not doing 200 off !
Posted: 11 Apr 2018, 18:45
by webtrekker
How are you creating your cutlines? ..... with the Pen tool?!
I can load a design into Photoshop, fill it with bkack on a white background and vectorise it in seconds with one click in VectorMagic. That's how I do all my vectorisation for print and cut or just contour cutting unless it's a vector design I've made from scratch.
Posted: 12 Apr 2018, 09:04
by froggy
Your artwork time should be £30 ish(unless you are going to use the artwork again on a regular basis).
Dont know your shop rate, but for arguments sake £60/hour possibly so thats another £15-£20. Then you want some profit on the £60. So £30 a decal?
Your machine is too slow to make money in this niche, unless your are producing smaller decals and leaving the machine for an hour or 2 to get on with it(using print ready artwork). If you can produce 50 decals an hour @ £2 each then the numbers start to work, preferably while earning producing something else at the same time.
