Re: Thermoshrinkable Foil Wrap
Posted: 22 Mar 2018, 18:44
Does anyone know about this heat shrink foil instead of silicone wraps? To use on bottles/ceramics etc in an oven
I can't find any UK suppliers, only seen it as below on the Polish Bestsub site. There's a video there of it on a roll, but the site is only selling it in cut sheets (too expensive at from 22c a go). I'm wondering if a roll would allow you to try all sorts of product shapes and sizes without having to buy a silicone wrap for each item. Also once you've got the hang of quick even heat shrinking, will it save time wasted wrestling with wraps.
But only if it actually works and applies the right amount of pressure from shrinkage only?
Could it handle handles, or only smooth sided cylinders.
Shipping's a bit high to just buy a bit to test from below, although I will try to get some.
Has anyone had any experience of it, or know if a UK Supplier? Thanks!
https://shop.bestsublimation24.eu/produ ... blers.html
