Glow in the dark vinyls
paul 44
Re: Glow in the dark vinyls
Post by paul 44 »
hi
Anybody know of a good supplier that does various types of glow in the dark tshirt vinyls, MDP only do silver glow flex but I need to give a choice of various colors to the customer as silver isn't an option for her?
logobear
Post by logobear »
the glow in the dark medias that I have found are VERY weak. If you had been in a cave for about an hour, you might see the glow, but it is not as exciting as say a watch face by a long way.
TMT also do a 'reflects' product, as seen on Hi Viz jackets that really pop if photographed using a flash, but they don't glow.
Maybe there is better media, - get your Geiger counter out!
logobear;129903 wrote:the glow in the dark medias that I have found are VERY weak. If you had been in a cave for about an hour, you might see the glow, but it is not as exciting as say a watch face by a long way.
Yeah, I've seen t-shirts with flexible electroluminescent (EL) panel designs sewn in and they are BRIGHT! Colourful too and some are animated.
paul 44
Post by paul 44 »
I've went for yolos nightclub UV reactive vinyl, the customer has black lights so this stuff should do the job
FlexCut Sticky NightClub heat transfer film is designed for transferring white logos, graphics or text onto cotton and polyester fabrics. The specially designed UV reactive film is fluorescent under black light making it perfect for dance wear and costumes.
