Application tape or carrier tap
dye123
Re: Application tape or carrier tap
Post by dye123 »
Wonder if anyone can help?
I need to get my images that I weeded to come off the transfer paper without picking them up with my fingers. Is there any type of masking tape i can apply it to and then heat press onto the garment to keep all the single letters lined or will it the damage my transfer?
mr-gobby
Post by mr-gobby »
If this is for textile vinyl then yes you would use a transfer tape usually available from the same supplier you bought the vinyl from
John G
Post by John G »
If this is t'shirt vinyl that you're cutting on a plotter - why do you want the letters to come off the backing paper. Before cutting the vinyl, reverse the text/image on your computer, or cutting program - cut, weed, then turn the sheet upside and press directly onto the shirt.
