Re: Help neded about image transfer
Posted: 02 Oct 2017, 16:38
Hi Everyone. new to this forum and I have to admit that I have never used the sublimation process. I will give you a little background about what I do and what I am trying to achieve with the advice of you experienced guys and girls on here please.
I produce artwork via Adobe Photoshop, I currently use a normal A4 laser printer to print these images off and then use a gel medium process to transfer the art work onto the substrates that I use like pallet wood etc. However I am now looking at producing more items and at larger sizes that what my A4 laser printer will only do. I would be looking to utilise a change in substrate such as using birch plywood if possible
I have looked at varying products from heat presses and sublimation printers, to UV flatbed printers and DTG printers but I am finding conflicting information online from my searches in regards to being able to transfer images onto different surfaces.
I understand that going down the UV printer route would eliminate all my queries, but the cost of these devices is around £8k upwards which is nothing I can afford at the moment. The cheapest option available is via a sublimation printer and heat press, in terms of price comparison.
What I don't want to do is purchase equipment and then find out that it wont do what I want it too. So my question is, if I want to print a design in A3 format on to say a piece of A3 plywood would I be able to do this successfully with the right sublimation printer and a heat press ? or would this not be possible.
I am at a loss at the minute at what to do. I want to start producing larger pieces of work but do not know what is the best option.
Any help would be great please
Mark @ Kikozo
Mark @ Kikozo
