Re: Full height printing
Posted: 15 Nov 2010, 22:50
by PhilTheMug
Is it possible to print (using mug press) the whole height of the mug as shown here?
http://cgi.ebay.co.uk/Tiger-Woods-Golf- ... 3a474a971a
Phil
Posted: 15 Nov 2010, 23:19
Yes, with a decent mug press full wrap is achievable. The usual issue that causes a problem is that the mug edges aren't straight. The mug tapers a little at the top edge. A good press allows for this.
Posted: 15 Nov 2010, 23:43
by purpledragon
quite a lot of mine are full height and i rarely have problems as justin says you need a decent mug press
Brett
Posted: 16 Nov 2010, 08:05
by PhilTheMug
I've PM Martin asking for a starter pack 'deal'.
Posted: 16 Nov 2010, 08:43
by NASH
just move the mug up the press and press the bottom part of the base
Posted: 20 Nov 2010, 07:49
by logobear
The main issue is incomplete Transfere around the bottom as the ceramic base draws out heat.
If you put an inch of boiling water into the mug to pre heat it for a minute before emptying drying and pressing it is usually good.
Posted: 29 Nov 2010, 20:11
by snjokaggl
I've found with my heat press that this is unnecissary because the heat press starts at 110c and climbs up to 180c before starting the timer so the mug get's pre heated and the bottom comes out great.
You should contact Martin as he has this model that I'm using.
Posted: 29 Nov 2010, 20:19
by bms
We've the standard models of these coming back into stock again tomorrow (Tuesday) - the DF1.
Posted: 30 Nov 2010, 09:29
by fredster
i have the new model from martin too and its the dogs b ......s :D wish i :D 'd have bought it sooner ...
Posted: 30 Nov 2010, 18:55
by smartarts
The DF1 mug press from Martin is great, most of my mugs I do a full wrap on with no problems. I have images on my gallery that you can see.
