Page 1 of 2
Re: ST3042 thermostat
Posted: 12 Aug 2017, 17:50
by paulswanton
Hi
Does anyone know where I can source a replacement thermostat for an st3042 - stuck on 19 degrees when warming up then trips RCD so guessing it may be thermostat (unless anyone knows better)
Thanks in advance (and hope)
Posted: 13 Aug 2017, 10:18
by malkram
From Sunmeta (the maker), it's quite cheap. I have their pricelist and contact details if you want (PM me).
Posted: 30 Jul 2021, 16:02
by Allthingsscilly
I have the same problem so I think I require a new thermostat. Just went onto http://www.sunmeta.com, but can't locate a thermostat
in their listed products, but have emailed their sales.
Posted: 30 Jul 2021, 17:04
by paulswanton
A new thermostat solved the issue for me. It only cost be a couple of pounds. I would suggest getting a few as the postage costs are quite high. Also you might want to consider getting a spare mainboard at around £15 in case it’s something more serious. Their sales department are very efficient02 main board
3D-14 heating sensor
Posted: 30 Jul 2021, 17:48
by Allthingsscilly
Hi Paul,
Thanks for replying, I take everything you said on board. I made another attempt today at printing a plate in my machine.
I removed the vacuum section and put a plate into silicon plate clamp. I took a long time to get the temperature up
195c, in fact it carried on past to 205c. In getting there the temperature went up and down. In fact when it started
it claimed the temperature was 105c!? After cooking my plate for 6 mins. I literally cooked it. The paper went brown,
stuck to the plate, the image brown and the plate cracked! So clearly getting hotter than it says. I won't do this
again as I will probably ruin the machine altogether.
I did removed the cover at the back to inspect as that is where the bang came from last night. Not the vacuum pump
as this still works fine. Only about 3rd time I have used the machine, but out of warranty as not used for a year
due to Corvid etc. Could detect no flash marks. Maybe the bang was in the lid, but it would have to be toward the back.
I take it the thermostat is in the lid? Occurred when I pressed the heat button once, so had not activated the bottom
heating element only the top one.
Hopefully I will get a reply to my email tomorrow and will purchase a new control panel just in case etc.
Posted: 30 Jul 2021, 18:04
by paulswanton
Do you get the same issue with excess temperatures with just one heating plate? Ironically I’ve also got the ST-420 model as well and experienced the same issue a couple of weeks ago. I heard a bang and the top plate temperatures went off the scale. I replaced both the temperature sensor and the top heating plate but it didn't resolve the issue. The machine starts to beep when it reaches temperature but doesn’t stop heating and also there seems to be a 50 degree difference in readout vs external laser temperature check. Hopefully someone with more experience can shed some light on this and help us both. My machine also has light use like yours.
Posted: 30 Jul 2021, 18:14
by Allthingsscilly
The experiment I conducted today also showed the temperature continuing to rise after the machine began to bleep. Took an awful long time to get there. because it would fall keep falling
by 20 degrees then starting rising again. At one stage I didn't think it would get past 130c as it reached this temperature 3 times then falling back before passing it.
Posted: 05 Aug 2021, 14:42
by Allthingsscilly
Still not got any where with getting a thermostat from Sunmeta. Had an email 3 days ago asking where I bought my machine from?
Since replying to that nothing?
Posted: 11 Aug 2021, 10:02
by Allthingsscilly
Hi Paul, Do you know anywhere else I might purchase the thermostat etc. Sunmeta have refused to sell me one or help me at all!?
They said I they won't help me because I didn't purchase the machine from Sunmeta. I then asked the contact Jim King if he could tell
me where I could purchase one and basically no reply after several days. Not exactly impressed with Sunmeta :-(
Posted: 13 Aug 2021, 12:36
by paulswanton
Hi - that’s surprising - I had nothing but help when I contacted them (granted in was back in 2017). They have many sales email addresses (i used sales09@sunmeta.com - Lisa Wu)
The parts you need are 3D-02 for the main board and 3D-14 for the heat sensor - should cost around $20 but will probably cost another $20-30 in postage
