Page 1 of 2
Re: Compatibles versus sawgrass?
Posted: 31 Jul 2017, 08:07
by carolm1a
Hi everyone
I have genuine sawgrass inks in my printer at the minute but I'm toying with the idea of replacing with compatibles? I have a cartridge just run out so need to try and work out whether its a good thing to do...or not LOL
Does anyone run with compatibiles?
Posted: 31 Jul 2017, 09:52
by UK Printed Mugs
Never mix but always match whatever you do so you will need to replace all four at the same time. You will need to flush out the lines if you do replace and will need a custom ICC profile.
Posted: 31 Jul 2017, 09:54
by carolm1a
Thank you. It may actually work out more expensive to do that so i'll just stick with genuine for the time being.
Posted: 31 Jul 2017, 10:54
Speak to Dyesubsupplies about SubliSplash, they provide a full flush set as well
Posted: 31 Jul 2017, 13:15
by DyeSubSupplies
Hi Carolm1a, I will give you the link below to the sublisplash ink on our site, we also have an offer on the swap out kit for a limited time.
http://www.dyesublimationsupplies.co.uk ... mation-Ink
Kind Regards
Steve
Posted: 02 Aug 2017, 20:28
by technick
Do you need an ICC profile for these or can they run off powerdriver?
Cheers
Posted: 02 Aug 2017, 22:45
by DyeSubSupplies
There is an ICC profile that you install into photoshop and print via that no need for powerdriver.
Posted: 03 Aug 2017, 06:41
by carolm1a
Thanks all will take a look at this
Posted: 03 Aug 2017, 07:37
by mrs maggot
I have recently made the switch to TPI, I use refill carts. initially I had only just changed my black, so ran with TPI in 3 and Sawgrass black, I noticed some difference, but not much.
Now I am running on 4, and still using my powerdriver as was told it might work ok, but I was also given a new ICC profile as part of the service offered.
The replacement refillable carts were around £28 for my model printer, and the inks were about £70 but that is for 100ml bottles, so a huge price difference.
I always have found it infuriating when changing ink carts just how much precious ink was left still in them, yet they registered empty, weighing them and working it out, I was throwing away about a tenners worth of ink!
Posted: 03 Aug 2017, 07:51
by carolm1a
Thank you - I'm going to take a look at this. Each of my cartridges is about £50 for 29mm so its working out expensive. Especially when you pay £60 and realise its the wrong cartridge when you open it ugh!
mrs maggot;124840 wrote:I have recently made the switch to TPI, I use refill carts. initially I had only just changed my black, so ran with TPI in 3 and Sawgrass black, I noticed some difference, but not much.
