Page 1 of 2
Re: Help please Black print has a green haze
Posted: 05 Jun 2017, 18:37
by TonyBadgeSolutions
Can anyone help. I'm using a Sawgrass SG400 printer. Recently when printing black text there appears to be a greenish haze around the text.
It has only just started doing this. I've tried different print settings and it is the same regardless what I try.
All the printheads are clear and test prints all come out fine.
Almost at the point of throwing the printer out of the window and getting a new one!!
Posted: 05 Jun 2017, 20:31
by Quinsfan
What ink are you using?
Posted: 05 Jun 2017, 21:34
I'm using the Sawgrass Sublijet HD.
Posted: 05 Jun 2017, 22:27
by DyeSubSupplies
Rather than throwing the printer out of the window Tony have a look into the sublisplash ink, the black is stunning. If you need anymore info or some printed samples email
adam@dyesublimationsupplies.co.uk and he will be able to help you out.
steve
Posted: 05 Jun 2017, 22:56
by webtrekker
What paper are you using, and what items are you printing onto? Have you recently changed paper type, or item brand, or supplier? Personally, I can't see how SubliSplash would help if you previously had no problems.
Posted: 06 Jun 2017, 08:23
by Customprintwales
I agree with the paper issue for this.
could be a bad batch of paper or even some dampness which is causing the black ink to run and diffuse slightly which would give a greenish haze. Think those childhood games of dropping ink onto blotting paper or filter paper.
Posted: 06 Jun 2017, 09:05
Is your black 100% black? What have Sawgrass support said?
Posted: 06 Jun 2017, 09:14
The paper I use is the Epson photo quality inkjet paper. I've been using this paper for over 15 years and have never seen this problem before.
I have just noticed that the black ink has an expiry date of Jan 2017, so is most probably what is causing the issue. Shame the cartridge is still half full.
The black is 100% black and sawgrass have not got back to me yet.
Posted: 06 Jun 2017, 09:25
Posted: 06 Jun 2017, 09:32
Make the change to Trupix paper you'll notice huge improvements. Sawgrass will immediately suggest replacement.
