Re: 9cm coasters
Posted: 05 Mar 2017, 14:18
by robhil
Bought some 9cm square wood coasters from listawood, do they come with a protective film as I am having a right job trying to remove it.
Re: 9cm coasters
Posted: 05 Mar 2017, 14:24
by ArferMo
Touch it quick onto a hot platen then it comes off easy
Re: 9cm coasters
Posted: 05 Mar 2017, 15:06
by robhil
Tried that I don't think there is a coating on there.
Re: 9cm coasters
Posted: 05 Mar 2017, 15:21
by robhil
Just printed them and they seem to have printed ok, if there was a coating I would have thought it would have melted.
Re: 9cm coasters
Posted: 05 Mar 2017, 17:58
by ArferMo
if there was a film on it the heat causes it to shrivel and then you can take it off easy.
Re: 9cm coasters
Posted: 05 Mar 2017, 19:19
by catcapers
The 9cm raw back coasters from Xpres do not have a protective film but the cork back coasters do have a film so this may be the case with the Listawood stock too.
Re: 9cm coasters
Posted: 05 Mar 2017, 20:36
by UK Printed Mugs
At least with a protective film you know that no dust particles are present and so can be placed down onto paper straight away after removal. With Unisub then you can spend more time wiping away small particles that can ruin a print.
