Hi guys,
I was just thinking last night as I was doing some mugs .............. what's the shelf life on a print (subliminal ink) ?
What I mean is, can you print out a batch of a 'popular' design that can stay on the side until required ............... or does the print really need to be used within a few hours because of the ink etc?
I'm probably like everyone at the moment that I print stuff out as and when I require them as some mugs require personalisation on them - but it may be a point to note if I have something that doesn't require any personalisation.
Adam
Shelf life for prints?
Re: Shelf life for prints?
I kept some for over 6 months, they took on a yellowish tinge but once pressed onto the mug they were fine.
Cheers John
Cheers John
Thanks Guys
Don't see there being a problem with printing and storing so long as you do the standard things like keep then flat and I'd suggest in a folder to stop sunlight fading them.
