Re: ciss system help
Posted: 11 Jan 2017, 21:07
by hannahvidler
we have a Epson sx215 the question is weve found the ciss system for it but the ink it comes with can we use on transfers etc
http://www.ebay.co.uk/itm/Compatible-CI ... FGQ9iNwteA
Posted: 11 Jan 2017, 21:41
by willd
That particular seller is selling dye based inks, which are fine for everyday printing.
We use Epson durabrite ink for transfer printing, which is a pigment ink.
When printed onto a garment, the dye based inks tend to fade very much more quickly when the garment is washed than pigment based inks, thus you're better off using a pigment ink.
Unless anyone knows better :-)
Posted: 12 Jan 2017, 09:41
by hannahvidler
Posted: 12 Jan 2017, 09:43
by hannahvidler
I'm guess that the correct stuff to use on transfers ( sublimation )
Posted: 13 Jan 2017, 07:05
by sinGN
Hi,
Yes you can use on transfers.
Posted: 13 Jan 2017, 09:14
by willd
hannahvidler;119257 wrote:I'm guess that the correct stuff to use on transfers ( sublimation )
I think that is dependent upon which transfer papers you are using - not all are compatible, so you need to check each type before using it...
