Shirts being marked, possibly burn?
apexhitter
Re: Shirts being marked, possibly burn?
Post by apexhitter »
So i'm pretty new to all this having only done a couple of small runs with dark 100% cotton tshirts and vinyl which have turned out well, but wanting to try different things i've bought some white tshirts to make myself some 1 off designs before trying to sell anything to the general public (self-confessed tshirt addict lol).
Using MDP i bought in some FOTL Super Premium tees and some Russel 65/35 poly/cotton blends to try out different types of vinyl and my sublimation printer.
What i'm noticing is that the press area has a slight yellowing discolouration after pressing, this happens when i'm using either process.
I have been using the manufacturers guidelines for temp and time, and i'm assuming if it's happening with the lower temp/time setting with the vinyl process it's something other than the press not being accurately heated?
I've used the search and found another person with the problem but that was with dye sub and used tees so i'm a bit stumped.
Could the teflon sheet be transferring it's colour (teflon sheet also from MDP)? Am i using too much pressure?
Hopefully someone a bit more experienced has some input on this :)
Press i'm using:
UK Press HP3805B
Thanks in advance,
Chris
pw66
Post by pw66 »
Go down the road to Novachrome and try a ream of their pressing paper - about £20 for 500 large sheets. They are in Anglesea.
Sometimes, when pressing polyester garments, the heat will cause the dye to 'gas' ( in a similar way that sub ink does) and mark the teflon sheet, or worse, the platen. The dye can then transfer to the next garment, if it is a light colour. Hivis and Football shirts are the worst for this, but any coloured polyester can cause the problem.
It is a process known as 'Dye Migration'. More usually you will notice it when the colour of strong coloured garments discolour the vinyl or ink used for printing.
apexhitter
Thanks for the reply pw66, i'l head over there and get some, hopefully it'll be as easy as that to solve.
I'll try a brand new teflon sheet as well i think in case it has migrated into the used one
