Hi there all,
Been attempting to install an extended ssl certificate on opencart from GlobalSign for my website www.readingprint.co.uk as I didn't want shell out £300 that was what the guy who did my site wanted to install it. I have installed it through cpanel and it says everything is fine, I have gone through my opencart admin control panel and in the options under server it said use ssl that was set to no. So I have now set it to yes but it is telling me to add the ssl url to the catalog and admin config files, now this is the part I am stuck at any help would be much appreciated
Thank you in advance
Damian
SSL Certificate install on opencart
- Reading-Print
Re: SSL Certificate install on opencart
Using Ricoh Aficio A4 sublimation printer, Epson 1500w A3 sublimation printer, Xpres heat press, ST3042 3D sublimation machine http://www.readingprint.co.uk
Damian been long time since i used open cart but from memory you need to state if it www.sitename.com or just sitename.com by editing those two files.
