Re: I am having trouble starting 3D Vacum Heat Press Machine in UK - please help!
Posted: 22 Jun 2016, 20:29
by Spaceman
Hi everyone, I really need some help! I have recently bought the machine in the link below however I bought the 110v version! The sockets in the uk output 240v I think.
As I am in the UK this is not compatible with our standard socket output. I have tried a standard converter plug but noticed some smoke from the socket - so that wasn't a good idea. Then I tried a step down transformer but the fuse of the transformer keeps going!
There must be someone out there that had a similar problem or knows how to get round this?
Any help will be greatly appreciated.
This is the machine I am referring to:
https://www.amazon.com/dp/B0124U35K0/re ... G57M4S2T3X
Posted: 22 Jun 2016, 22:45
by malkram
No clue sorry, better call an electrician that will find a suitable and secure solution.
Posted: 06 Dec 2016, 18:27
by Bigd
Hi what transformer did you use was it like this one https://www.pat-services.co.uk/110v-3-p ... AnJm8P8HAQ
Posted: 06 Dec 2016, 19:01
by GoonerGary
Does it say 110v to 230V on the back somewhere?
Posted: 06 Dec 2016, 19:30
by Adrian B
This unit is 120v only - It does clearly state this in the two of the Amazon pictures as well as the description. I don't think that there are any internal fuses in this product to protect from this level of over-voltage. Ask a qualified repair technician for an assessment. You may be able to get a 230 v PSU and get that fitted but this is likely to be reasonably expensive..
