Hi all,
does anyone do a transfer for a black gloss mug? might need 250? can you print and cut these with a bn20 or sp300i?
many thanks
black mug printing
FutureProject
Re: black mug printing
I always worry colour matching will be a nightmare with them, anyone tried them? depending on the durability requirement, there are laser papers for hard surfaces and laser printers that print white.
We print lots of black panel mugs....... when they are available. Been a big shortage for the last 6 months. Takes time to get right but once sorted they look very good. In direct sunlight you will always see the panel though. Under normal conditions inside you have to look for it as it can blend well.
so you print onto the white panel with a black background to cover with your logo on top?
Yep. The unused part of the design you flood with Black to try and make it blend.
