Re: Powerdriver questions - SG3110
Posted: 17 Apr 2016, 16:25
by technick
Hi there:)
6 months into buying my Ricoh 3110 and have ad nothing but bother with colours, i have finally settled on the powerdriver which is a big improvement but need to clarify a couple of things....
I am using Powerdriver v4 (not the US version)
I have my Document profile and working space set to "SRGB". Should i continue in this way or use Adobe 1998? (i work with watercolour swatches)
Which substrate is best for printing onto mugs? I currently have it set to Unisub.
And do i let Illustrator determine colours? There is no option to let me choose any other option but have been told to let the printer determine by a few folk?
Cheers
Nick
Posted: 17 Apr 2016, 16:52
You need to follow the Sawgrass setup files to set software up.
Mugs should he ceramic.
Posted: 17 Apr 2016, 23:47
by technick
Thank you Justin.
Sawgrass set up advises using SRGB as a working space however Adobe 1998 offers a slightly larger colour space. Am I able to use 1998 with the powerdriver, and would it give me overall better results than SRGB?
Posted: 19 Apr 2016, 10:08
by mags1892
sRGB if powerdriver - ADOBE rgb if direct, you SHOULD get best colours with direct but you would need a custom profile.
Posted: 19 Apr 2016, 13:09
by technick
Cheers mate, definately getting better results with Powerdriver (have to increase saturation in printer settings)
Posted: 19 Apr 2016, 14:22
by mags1892
settings for illustrator is srgb if using those for document or adobe if usign this. then no colour management happening in illustrator anything else and your blacks will appear brown amoungst other things depending on percaptual or reletive colourimetric.
Posted: 19 Apr 2016, 16:21
by technick
Yep i have tried with Adobe 1998 printing direct using all four AI settings (Perceptual, Saturation, Relative, Absolute) and still can't get anywhere near powerdriver quality.
I work with custom watercolour swatches, most of them are coming out ok but yellow (faint), green aqua (coming out blue), dark wine (almost black) not so great.
Posted: 19 Apr 2016, 16:55
by technick
One last question on this... With the powerdriver.... the only option i have is to let Illustrator decide the colour handling. Is this correct, or should it be the printer decides?
Posted: 20 Apr 2016, 11:04
by mags1892
If you chose srgb in illustrator thats the same as letting printer decide. illustrator only supports POSTSCRIPT devices for proper colour management.
