JPSS cutting with a cameo portrait
paul 44
Re: JPSS cutting with a cameo portrait
Post by paul 44 »
Hi Folks,
Just a quick question, I am using a silhouette portrait cutter and am wondering whether I can use it to cut through JPSS paper for a cleaner print?
As all of you know who have used this paper, some emulsion can still be seen on the print so I need to cut through both layers (emulsion and backing paper) for a better looking result, has anybody tried this with a cutter on jpss?
KathG
Post by KathG »
I don't have that exact cutter but you should be able to. I would to some test cut outs to get your setting correct first.
Cheers
Kath
paul 44
Post by paul 44 »
I was looking at a few videos on it and it looks like I can cut just through the printing material where the image sits but the backing paper is left on throughout the entire image, the cut is eventually peeled off leaving you with the full print minus the excess printable material (printed membrane)
I'm not sure how this would work or whether it would scorch the shirt as there is only so much printable membrane on the print but hoping it will be ok.
I may do a test print tonight to see how it works.
Vynmarius
Post by Vynmarius »
Hi mate I had a silhouette and managed to cut the excess away, when I did it, wasnt too much trouble on smooth cuts and it worked just like the vids, although I reccomend using something sharp to get the peel going
ryanmontgomery
Post by ryanmontgomery »
I do this, I found it works well and you won't scotch the tshirt. It's a better finish all over.
