Re: Roland GX-24
Posted: 09 Sep 2010, 18:39
by jennywren
I've told that theRoland GX-24 can also do contour cutting, and is the best for the job even for a novice. has any body use one of these are they as good as the say. Or is there another plotter/cutter (no limit on price within reason)that you would recommed for for contour cutting.
Re: Roland GX-24
Posted: 09 Sep 2010, 21:44
by Kaz
Silly question time, but what is contour cutting?
Re: Roland GX-24
Posted: 09 Sep 2010, 21:51
Do you mean contour cutting as in print a design and then use the cutter to cut the outline? If so then yes, it has the optical eye needed to do this. It can read the registration marks printed.
I used to do this on my CX-24 which is just an earlier model. The Roland cutters are excellent. ;)
Re: Roland GX-24
Posted: 12 Sep 2010, 09:27
by jennywren
Yes it for the outline, but have very little knowledge of cutters plotters, but need to expand the t.shirts side of things, I also want do to car stickers. I have spent days reading of the various plotters/cutters and this seems to have a steady good write up. I have only one place to buy it and they did'nt have a stand, will I need one
Re: Roland GX-24
Posted: 27 Oct 2010, 21:18
by Flash
jennywren wrote:I have only one place to buy it and they did'nt have a stand, will I need one
Hi,
Not necessarily. You can use any cutter/plotter on a desktop, but you will need a bit of space! This is generally the reason for a floorstand.
I hope this helps.
Phil
