Hi vis printing tips
Re: Hi vis printing tips
Hi guys,
Just a quick question, I have a customer who is looking to have a load of hi vis vests printed but I haven't printed on hi vis clothing as yet and was wondering if there are any tips on printing vinyl onto these.
It looks like just a company name and possibly also an individuals name.
Tips on press time and heat settings and i'd also like to know whether the hi vis material can take the heat from the press as I will be using MDP FLEX vinyl.
cheers
cheers
Firstly, if you are just printing black then sublimate them, its a better finish.
I am printing about 500 a week and press them for 45-50 seconds at 185 degrees but its worth pointing out that I am using the cheapest ink possible and Tesco printer paper (£2.50 a ream!). Obviously you could a reputable ink and a decent release paper and it will work just as well, but I am not sure what the times will be with them. I only use the cheapest possible as method I do so many.
If its a colour logo then it might be possible (with a bit of playing) to get close with sublimation, but that depends on the colour you need to achieve. If not then vinyl is the option and you will have no problems pressing.
Lastly, if you want to PM me I can probably supply your vests cheaper than anywhere else as I buy mine in bulk at 5000 vests at a time
S>
S>
HI,
these will be provided for me as they have already bought their own hV's, i'm just hoping there is no reflective banding across the center of the back as this may end up scorching.
Hi Paul,
As long as you put a teflon sheet over them it will be fine. I use vinyl to do my hi-vis vest and it works a treat.
Let us know how you get on.
Danny
Danny
As long as its not the cheap plastic stuff then they will not scorch.
Well she got them off ebay so yes they are probably cheap, she was quoted just over £5.00 to get printed ones but decided to get blank HV's, she wanted 10 doing so I quoted £5.00 to print each vest with a logo on the front and wording on the back on each vest in vinyl, she thinks that is too expensive!
As far as teflon goes, i have always used the normal baking paper you get from supermarkets, seems to do the job, reading up on it it seems like they are both more or less the same stuff but I always check temperatures that the sheet can handle, I just wasn't sure of the material that HV's are made of as I don't want to turn them into liquid HV's lol
Thanks again
Thanks again
some people want everything for nothing. unless you are in our industry they dont realise the time/effort it takes to do something. i charge people £5 per location if bringing stuff in. what are others charging/doing? brought in products?
i wouldn't do 10 items front and back for £5 each......
agree with calvinabc, Everyone wants something for nothing. i doubt they could get them cheaper in a shop! the main thing is you dont feel pressured into dropping your price and then essentially doing the job for free. Done that on many occasions. it will always be a lose/lose situation if you go down that route as the customer will still not be happy and you wont be happy doing the work.
Ive decided that I won't b doing the vests, may as well do them for nothing as has been said, it is for a church. Not gonna spend a few hours on those when i could be designing something.
