Re: Colour changing mug issue
Posted: 15 Nov 2015, 11:43
by abacus1983
Hey all, I done my first color changing mug the other day, I'm using the jtrans mug press and mugs from dyesublimationsupplies settings as suggested for there normal mugs on there website, 110 resting temp, increasing to 180 when mug is inserted then countdown for 180 seconds, the print came out perfect and really vibrant, my issue is when the cup cools and returns to black you can still slightly see the image, also you can see where the heat tape was and also the edge of the paper
hopefully somebody has an idea what to do
Best regards
Carl
Sent from my A0001 using Tapatalk
Posted: 15 Nov 2015, 13:43
by Quinsfan
Yep that sounds about right. I tried these and the image always shows through. Tried several suppliers all from on here, branded, not ebay and none of them worked the image always came through. Does the tape and paper edges show on your plain mugs?
Posted: 15 Nov 2015, 13:45
by abacus1983
Nah just on the color changing ones, I'm thinking maybe try wrapping the Teflon sheet round the cup and taping that together instead to get rid of tape marks but that still leaves paper edges and visibility when black to resolve
Posted: 15 Nov 2015, 13:48
by Quinsfan
It may be something to do with the colour changing coating these mugs have that effects the heat tape and paper. As I say I gave up when the images never disappeared.
by abacus1983
Well I have 4 more to experiment with
Posted: 15 Nov 2015, 13:52
by Quinsfan
have you looked in the similar threads box above these posts to see if there is an answer there before doing any more trials
Posted: 15 Nov 2015, 13:53
by abacus1983
Not yet, still getting the hang on the forum lol
Posted: 19 Nov 2015, 18:26
by viksta87
I have the same issue, i press mine at 200 for 60 seconds. Its like overbaking them (which with print makes the black ink go brown) If you heat the coating up too much it becomes a bit too translucent. Maybe try cutting the time down?
Posted: 20 Nov 2015, 14:27
by James990
or try heat 180 for 180 secs. Works a treat for me!
