Page 1 of 2
Re: dullish box problems??
Posted: 07 Nov 2015, 11:35
by michael
I drag images from internet. Vectors and jpegs
every time i print them out i have a dull grey box behind them....Please help im stuck
Posted: 07 Nov 2015, 11:53
by KathG
What graphic program are you using to print your images?
Can you post an example of an image you are using then maybe we can help you better.
Posted: 07 Nov 2015, 12:29
by michael
im using coreldraw 12 with an icc profile for sublimation
ive tried uploading image but cant find url
Posted: 07 Nov 2015, 12:36
by michael
i think its summat to do with rgb and cymk if im honest
Posted: 07 Nov 2015, 14:27
by Paul
if its custom icc profile then its more to do with temperature of the white. you need to have your icc edited to different white point.
Posted: 07 Nov 2015, 14:40
by michael
hi Paul.
yea i got my icc from yourself.
prints out normal pictures awesome.
everytime i drag image from net it always has greyish box around it. jpegs and vectors
do you think it could be settings ?
Posted: 07 Nov 2015, 14:47
by michael
is that something i can do or yourself?
Posted: 07 Nov 2015, 15:12
by Paul
if you mean by transparent images or those with white background print grey then yes, its white point. i can do it for you. pm me with your icc name and i will sort it out for you.
Posted: 07 Nov 2015, 16:34
by Quinsfan
Are you just dragging and dropping images from the net. It depende what kind of images but have you converted the image to a bitmap and then traced it or you could try a bitmap mask. The other way I have done it is to draw around the image using the beizer tool, make this an object, and then use the powerclip feature.
Posted: 07 Nov 2015, 16:40
by Brixhamboy
Oh my, this is getting very complex.
Perhaps it is something a little simpler?
I tend to think it is an RGB vs CMYK issue
