is it possible
Re: is it possible
Is it possible to do sublimation on enamel mugs, if so where can I get these. If so can the size of the enamel go in a normal heat press
Re: is it possible
I did but the time factor is at play, but i ween on the forum ( a great source of learning ) and found a thread about cpm and enamel mugs, so I going to have a play tomorrow and see if that works. Would rather sublimate as it would be easier.
