Re: Sublimation Dye, Epson XP-322, Installation Cartridges
Posted: 08 Aug 2015, 20:21
Hi there
1st post here. After many months of having an awful lot of kit loitering around the house, we have finally decided to try and get this show on the road!
We are setting up a CISS system on an Epson XP-322 printer. So far, we are encountering the following issues.
1. How to remove the air locks from the CISS tubing. I have attempted to remove them using a syringe but the ink began pouring out of the hole in the top of the cartridge! The circuitry has been placed in such a way that it obscures 2 (!) of the holes so I cannot insert the syringe properly. Can I go ahead and try printing? Will that remove the air after a few runs?
2. I have begun setting up the printer drivers/software etc. The system has asked me to insert the installation cartridges. I am aware however that mixing dyes is not a good thing. Can I go ahead and use the installation cartridges without having to flush afterwards? Installation wouldn't be using the CISS system, so my head tells me that once the installation cartridges are removed, their is no normal ink in the printer to be flushed anyway. Would this be a correct assumption?
Many thanks in advance.
Chris
Chris
