Rucksacks Creasing..
Ucase Ltd
Re: Rucksacks Creasing..
Post by Ucase Ltd »
Hi All,
Everything I've made to date has been in a 3d machine.
I recently bought a flatbed clam press from Coralgraph (just a cheapy - nothing fancy) to get my feet wet with some different products.
It's been great with hard items but trying to do rucksack flaps I'm getting crease marks in the final product.
Printing advice for these is light pressure (As far as I know I have to guess the difference between light/medium/hard as I have no gauge).
I've tried pre-pressing.
I'm using a silicone sheet over the top.
Would be grateful for any advice?
Thanks,
John.
ArferMo
Post by ArferMo »
how do you mean crease marks
Ucase Ltd
Post by Ucase Ltd »
Tried to email myself a picture as I don't have a cable to hand but it's not coming through.
Basically there are marks where the flap hasn't sat 100% flat so there are white "creases" that haven't sublimated.
JMugs
Has thanked: 11 times
Been thanked: 10 times
Post by JMugs »
I think I know what you mean. Leave the flap under the press for a minute or so with the press open. The fabric will get warm, smooth it out by hand, it should look smoother now. Then press it.
Ucase Ltd
Post by Ucase Ltd »
Thanks Jmugs - I'll give that ago :)
FutureProject
Post by FutureProject »
could also be too much pressure, I've had the same thing
Ucase Ltd
Post by Ucase Ltd »
FutureProject;103632 wrote:could also be too much pressure, I've had the same thing
Thanks - I'm still getting my head around what actually classes as light/med/heavy. With no gauge it seems to just be a judgement call.
ArferMo
Post by ArferMo »
Heavy... you should struggle to close the press.
Light..... put a sheet of A4 over the garment with the paper half in and half out of the press, close the press, you should be able to pull the paper out without tearing it.
Ucase Ltd
Post by Ucase Ltd »
ArferMo;103648 wrote:Heavy... you should struggle to close the press.
That's Really Helpful! - Thanks!
And "Light" is much lighter than I thought.
ArferMo
Post by ArferMo »
If you are using 3D techno it's even lighter than light else it can't expand.... it's a wonder how it sticks.
