Re: Are these any good?
Posted: 13 Jul 2015, 20:06
by Mugman71
http://www.ebay.co.uk/itm/NEW-IN-PNEUMA ... 41976d5af5
Are these any good or can anyone recommend a printer a mug press for under a oner?
Posted: 13 Jul 2015, 20:19
by Paul
this is definitely more expensive then it look like as it need a compressor.
Posted: 13 Jul 2015, 20:47
by Mugman71
Paul;102963 wrote:this is definitely more expensive then it look like as it need a compressor.
Says it doesn't?
Posted: 13 Jul 2015, 22:03
by pisquee
not a fan of vertical mug presses
Posted: 17 Jul 2015, 09:34
by Mugman71
pisquee;102970 wrote:not a fan of vertical mug presses
I brought the following
http://www.ebay.co.uk/itm/10oz-11oz-Mug ... 576200926?
Now before anyone says its cheap and horrible my last press pressed around 3000 mugs and that was £70. So I opened the box, there is no instructions but that isn't too much of an issue but would have been if I was a heat press newbie. So I set the temperture and the timer. Here's the thing; there's no button to turn off the alarm or start the timer?? I have messaged the seller and called but no reply, any ideas?
Have a feeling this is going to be returned.
Posted: 17 Jul 2015, 13:29
by Reg
The timer is probably on the lever starts when you close it stops when you open it usually operated by a micro switch
Posted: 17 Jul 2015, 17:05
by Mugman71
Reg;103081 wrote:The timer is probably on the lever starts when you close it stops when you open it usually operated by a micro switch
Sorted it now, I have been sent a faulty one as the enter button don't work!
