Ricoh GX7000 errors
kermit
Re: Ricoh GX7000 errors
Post by kermit »
I picked up a used Ricoh GX7000 which just needed Cyan ink. Ink arrived today and installed.
Getting 2 errors:
Paper misfeed/press form feed
Error 990.
I will investigate later, but wondered if anyone knew a quick fix.
If my memory serves me right I think that is to do with air in the ink lines.
I think you can solve it, but the solution is often a bit patchy. I would suggest googling the error code and see if Conde have a solution.
kermit
Post by kermit »
socialgiraffe;101621 wrote:If my memory serves me right I think that is to do with air in the ink lines.
Thanks socialgiraffe. I will have a search now.
kermit
Post by kermit »
Finally got rid of the 990 error with some help from Listawood and a Conde video.
Only problem now is its used most of my ink!!
