Re: Using cutter to cut out mug templates
Posted: 22 Mar 2015, 17:55
Is there any reason why I can't get my cutter to cut the mug templates out for me?
Let's say I want to insert 12 mug images into a page in CorelDraw/Illustrator, add registration marks and get the cutter to cut out or perforate each mug template for me.
I tried setting up a document in CD to do this, adding snap to but can't get it to snap the images properly to the template.
All seems possible in theory :-)
Posted: 22 Mar 2015, 19:23
by socialgiraffe
You can but why ;-)
If you are still looking at the volume you have been talking about previously then I would consider a print and cut machine that is converted to dye sub inks. Not sure if a Roland can be converted but I know at least one make of "PnC" can as LTS have it.
With my Roland I can set up a kiss cut and a perforated cut on one file/job (ie. it can kiss cut a circular sticker and then cut a perforated square. All I have to do is pull apart and pack :-)). So presumably you can do it with others.
Posted: 22 Mar 2015, 19:31
Just something that interested me.
Yes, I could use something like this http://www.xpres.co.uk/p-8532-mimaki-tp ... chine.aspx
I'm more interested in how the file would be generated using the template.
Posted: 22 Mar 2015, 19:59
by socialgiraffe
That will be cheap to run and very fast with double colours ;-)
Aha, not sure on that part, sorry mate.
