Page 1 of 2
Re: what machines professional ppl use for 3d wrap cases
Posted: 08 Mar 2015, 16:13
by Ravisteam
Hi guys .what machines these pro ppl use to print 3d prints .? Cos these chinease machins more of a hassel to print stuff and the results aint steady.
Posted: 10 Mar 2015, 12:48
by Simbak75
Are you referring to a specific 3D Heat Press? I use the ST3042, 3D Vacuum Heat Press (Chinese make). Initially I had no end of bother with it but things are coming together now.
For 3D 'hard' phone cases the settings I've found work are:
Temperature: 190C
Time: 9 minutes
Use a die specific to the case to help the case keep its shape.
Pre-heat the heat press to the desired temperature and use both top and bottom heating elements (press the heat button twice to turn both on).
I have only been able to test this on 4 cases so far, including an iPad case, but the end result has been great for all. If someone else has found other settings to work then please do share :)
Posted: 11 Mar 2015, 01:48
by emtp1839
I've got the ST3042 machine also. I've been running 3d cases at 196 degrees F for 7.5 minutes with good results
Posted: 11 Mar 2015, 07:02
by g1njeremy
This would be a hint:
http://youtu.be/N34_t_80tNQ
I don't believe any OTC Chinese machine can yet replicate their machine.
Posted: 12 Mar 2015, 21:46
by Ravisteam
Hi thanks for the reply ...Dont you see some sort of residue kind of a effect on Glossy cases ???...Do u know what Imean ??.
by Ravisteam
Simbak75;98952 wrote:Are you referring to a specific 3D Heat Press? I use the ST3042, 3D Vacuum Heat Press (Chinese make). Initially I had no end of bother with it but things are coming together now.
Temperature: 190C
Time: 9 minutes
Posted: 12 Mar 2015, 21:50
by Ravisteam
g1njeremy;98971 wrote:This would be a hint:
Lol..Thats how big ppl do ha ..Lol...
Posted: 30 Mar 2015, 10:07
by Simbak75
Sorry for not replying sooner, Ravisteam. I was on holiday and then ill.
I am not 100% certain of what you mean, however the end results of my cases are clear and sharp. No residue effect from what I can see.
Posted: 30 Mar 2015, 13:12
by Ravisteam
Simbak75;99637 wrote:Sorry for not replying sooner, Ravisteam. I was on holiday and then ill.
thanks for the reply.if i explain it again ,its like when you leave metal inserts in the heat press for bit longer you get the same effet( kind a burnt but its not much visible)..my 3d covers print great too but this effect cant be get ridoff..thanks
Posted: 30 Mar 2015, 13:18
by Simbak75
Ravisteam;99652 wrote:thanks for the reply.if i explain it again ,its like when you leave metal inserts in the heat press for bit longer you get the same effet( kind a burnt but its not much visible)..my 3d covers print great too but this effect cant be get ridoff..thanks
I see. I have not had this happen on any of my 3D cases but at this stage I have only done half a dozen or so. What equipment and settings are you using? It sounds to me as though the temperature is too high, the case is pressed for too long a time, or a combination of the two.
