Re: My First Ever Mug...
Posted: 11 Feb 2015, 14:54
by Ucase Ltd
Had my first go at printing a mug today.
It's not perfect but for a 1st attempt I'm a pretty happy bunny.
Just took these pics with my phone real quick..
vB_ID:3300
vB_ID:3300
vB_ID:3300
vB_ID:3300
Posted: 11 Feb 2015, 17:10
by AlanD
Looks pretty good to me. What press and mugs do you use? printing to the bottom can be tricky
Posted: 11 Feb 2015, 17:20
by Ucase Ltd
Thanks Alan! -
Some of the solid colours are slightly patchy and the black outlines have a little bleed but I think that's just because I didn't leave the print to dry for long enough.
I'm using the 3D-Sub Machine (ST3042).
The mugs were from Subli-blanks (dino-coated, their own coating).
Didn't do anything fancy - Just taped the paper-on, added a silicone mug-clamp (supplied with 3D machine) and job done.
Posted: 11 Feb 2015, 18:43
by AlanD
I normally print and press straight away but I am using a mug press - not sure that makes a difference. I've got some mug wraps coming (cheap green ones) so I'm going to try printing in an oven at some stage.
Posted: 11 Feb 2015, 20:19
by bobblehed
I did my first one today too, just had a quick play.
vB_ID:3301
vB_ID:3301
Posted: 12 Feb 2015, 09:49
by Ucase Ltd
AlanD;97564 wrote:I normally print and press straight away but I am using a mug press - not sure that makes a difference. I've got some mug wraps coming (cheap green ones) so I'm going to try printing in an oven at some stage.
I'm also just using the cheap green ones - They seem fine to me.
Let me know how you get on :)
Posted: 12 Feb 2015, 09:50
by Ucase Ltd
bobblehed;97569 wrote:I did my first one today too, just had a quick play.
Looking Good!
It amazes me that I went through hundreds of phone cases before I got them right but every other product I've tried has come out pretty good first time.
Posted: 12 Feb 2015, 10:26
by AlanD
I had great results first off with mugs and a press - 2nd and 3rd box of mugs (same supplier) were not good - mug tapering and top to bottom prints were a lottery, 1st box were no issue at all. I'm more curious than anything regarding the oven and I've just seen that the wraps aren't coming until well into March!! I must take more notice when ordering from Ebay:)
