Jet Pro Question
pieces
Re: Jet Pro Question
Post by pieces »
Does the Jet Pro Soft Stretch transfer paper have "Jet Pro Soft Stretch" written on the back of the transfer?
We have someone wanting to place a larger order for transfers with us, but we do not want them to know the type of paper we are using for obvious reasons.
How about If we buy it on the roll, does it have anything written on the back?
thanks!
raydavies
Post by raydavies »
Unfortunately it has "Jet-pro ss" printed on the back of the peel off backing. Why would a customer get to see that?
Ray
malfunction
Post by malfunction »
I take it they want the transfers supplied by you printed and contour cut for them to press themselves, I wouldn't think it matters that they can see whose paper it is as they are unable to print and cut there own.
ArferMo
Post by ArferMo »
Next they will be after a COSH certificate to see what ink you are using :rolleyes:
print, cut and then use mylar tape to transfer image. this way they won't know :)
ps: Im not sure if mylar will work with this type of paper so test it first ;)
