iphone insert Wrinkly?
petedale
Re: iphone insert Wrinkly?
Post by petedale »
Hi All,
I have just pressed a couple of iphone case aluminium inserts, they looked ok at first but then I noticed after closer examination that they seem to have a wrinkled finish, I definitely removed the clear protective cover off the blank but it does look like it has been pressed with it on!
I pressed them at 180c for 65 seconds as instructed upon purchase,
Any help would be highly appreciated
Thank You in advance :smile:
Wally
Post by Wally »
I have noticed this on a couple of mine also, would really appreciate anyones answers.Thanks.
By the way what are you placing on top of your insert when heat pressing.
ArferMo
Post by ArferMo »
I presume you are removing the protective film
Has thanked: 13 times
Been thanked: 12 times
Very light pressure, maybe reduce the time back to 50 seconds and make sure you print with the metal up. Put a long piece of tape along one edge, that way you can flip it over to make sure it's pressed ok, if not you can put it back in without the transfer removing and press a little longer :-)
Wally
Post by Wally »
Will try that Justin Thanks.
Mattie
Post by Mattie »
I second what Justin says
I press all my cases 190 for 55 secs light pressure never have any problems with the wrinkle anymore
Matthew
petedale
Post by petedale »
Thanks for the advice everyone, I am getting some nice results now, I think 65 seconds was a tad too long and i was putting far too much pressure on the plate,
All happy now :biggrin: Thank you
