Yolo v TMT v xpress v etc
Re: Yolo v TMT v xpress v etc
Dave271069;77493 wrote:When you say TMT isn't working, what do mean exactly justin? Is it not taking on the paper in the printer?
Takes paper in but getting stuck to the fuser unit just before exit.
^Socialgiraffe - Settings all set according to what I's been told :-)
And did they send you A4R paper?
I believe so but not been in the office to double check, will look tomorrow.
Renniwano
Post by Renniwano »
Just had a reply back from TT about the Exact Print and my new C511 printer
Thank you for your interest in the Exact print. The printer you mentioned, unfortunately, isn’t on the approved list of printers for this paper and if it isn’t compatible it will wrap itself around the toner and can be quite a costly repair. Please let me know if you would still like to test at your own risk then please let me know.
It's not looking good!!
When I bought the 511 I was informed by the supplier that it was the direct replacement for the 501 and had no physical difference that would cause any issue with papers compatible with the 501.
Renniwano
Post by Renniwano »
Do you mean the 510 ??
I am really dubious now about testing :/
Sorry, yes I think that was the one.
Renniwano
Post by Renniwano »
See it's the 510 that most papers are compatible with.. but like yourself went for the 511 because that's the new version of the 510 which is now being discontinued hmmm
Renniwano
Post by Renniwano »
So Justin.. in total are the papers mentioned so far the only ones you have tested ??
I am waiting on samples from Serigraf, the samples from Xpres were already printed up - so no good for testing the printer..
I'm still waiting for papers from Xpres believe it or not! Very slow. If they arrive pre printed I'll also be very annoyed.
TMT are sending more samples as it appears they should be compatible but I'm very concerned about them right now.
Is like to try other suppliers as well.
