mini 3d machine mugs
3D Sublimation
bigj2552
Re: mini 3d machine mugs
Post by bigj2552 »
after all that....
and it still aint that :rolleyes:
fan is now turning by hand freely.....
aint pump, fan ok now.....checked all wiring while i had everything stripped....fine.
only thing that left is something on the circuit board, maybe dry solder joint.....and i aint going in again tonight..SOD THAT :rolleyes:
see what supplier says on monday.....but at least i got the mugs coming out and know what the problem is.....and i also know this thing inside out lol :wink:
time for dinner
bigj2552
Post by bigj2552 »
update on this machine for everyone else.
contaced supplier - and its the condenser or what every you call it, at the very top thats knackered...thats what drives the fan,....
getting new ones sent out.
thats the only spare bit they dont sell....well maybe they will now :rolleyes:
i replaced everything else...so thats all that was left
galerion
Post by galerion »
On your working one have you ever had your fan shut off while your timer is running?
bigj2552
Post by bigj2552 »
galerion;88666 wrote:On your working one have you ever had your fan shut off while your timer is running?
watch for a proper seal when using these machines - read on -
started machine and vaccum....all's well. then 1 min into sublimating, the dreaded farting sound from the machine....
i knew it was the seal.....it cant have ruined another silicon seal...
let machine finish..took out case, half baked = bin....
looked to see if the silicon had small tear anywhere....nope...:confused: - fired it back up....same again...WTH :confused:
opened it back up.....you know what it was ?...a sodding HAIR.....yep, a single hair....i said, no, cant be just that....fired it back up and another case....PERFECT
unreal a hair can stop the seal from working
answer to your question my friend - the other machine's fan had NEVER stopped when cooking a case until 2 days ago.....half way through, fan stopped...no point in carrying on...stopped, case buggered...switched off machine thinking another condenser away, but it fired back up again....phew !!!!
i am ordering 4 of these condenser things that drive the fan for backup....just in case its a (another) weak spot in the build :rolleyes:
but, on the whole, now we know how to work this thing setting wise, it gives great results....mugs incl ! :wink:
just to master the full wrap for the mugs around the handles and we got there - like someone else said, i to can get the print onto the actual handle, but need to find a way to get pressure onto it - print is to faded due to not enough weight behind it - thats this weekends job, if we got time
bigj2552
Post by bigj2552 »
another update....
forget what i said above -
biggest piles of **** i have ever had the mis-pleasure of owning :rolleyes:
the working one i have left....when i do 4 cases one after other...when it gets to right temp and i heat the timer button to start sublimation, the bloody thing conks out
so it cant handle sublimating 4 cases one after the other - what a complete waste of sodding money and time..
will get the spares in that i ordered, but i really dont know why its doing this now......
over heating ??? -
my verdict - DONT TOUCH EM WITH A BARGE POLE - :mad:
will email suplier AGAIN, and find out what the hell is going on now....will keep you guys posted as i know others have bought these machines :rolleyes:
I think you need to face facts that you've been sold duff machines. You're giving very mixed messages about them ;-)
bigj2552
Post by bigj2552 »
Justin;88797 wrote:I think you need to face facts that you've been sold duff machines. You're giving very mixed messages about them ;-)
i,m begining to think that justin..i really am :frown:
i am uploading small vid to youtube just now....little smell of burning from this one.....cant be good.
i,m only telling others whats happening justin....all was going well up until tonight..as per my other post....
tonight is the first night i done 4 cases one after the other....the other times i done one, then waited 10 mins to do another
not a happy camper indeed to be very polite on here :rolleyes:
this is a warts n all review - more warts than anything else !
galerion
Post by galerion »
I was wondering if it was heat causing it to shut the fan off, really I think its been designed the wrong way round. All the components should be in the bottom and the tray should be at the top being as heat rises. Also although I fixed my back issue I have a mug that has blue, black and red writing on and the blue came out not as saturated as it should be so something else to tweek.
bigj2552
Post by bigj2552 »
think this is more than a tweak ;-(
this is not good for a business - either i got 2 duffers like justin said, or these things are utter junk, when you consider the cost price of these importing them, you really have to wonder..
yet another email away to supplier - not as nice this time round.....
what we really need to think now is....what do we buy to replace these ???...cause these cannot be relyed on.....imaging if we had a run of cases in...NIGHTMARE.
as it is, we got 3 orders in tonight...so hopeing it will work tomorrow, when it cooled right down till we get these out the way....
galerion
Post by galerion »
I haven't had it do that, I have had it need to be turned off and on again before fan would kick in regardless of hitting the timer button.
