Page 6 of 11
Re: Cutter .. Cameo ?
Posted: 27 Jul 2012, 13:35
by bigj2552
thanks paul....that aint even the work space lol......thats over the other side of the room :tongue:
right....need some info here....cameo print n cut....
looked on youtube......
to do print n cut it says i have to print design out with registration marks...yep, fine...then put it into the cameo and it will cut out the design...yep......
does that mean i will have to load the vinyl into the brother to get printed FIRST i take it...then take it out and fire it into the cameo for it to cut it out with the registration marks ?
if so....how the hell do i load it into the brother printer i got 5910dw.....its got a tray feed system at the bottom...and
WILL IT TAKE VINYL without jamming it ???....
or am i missing the point here altogether ? :confused:....early days yet :rolleyes:
anyone ?
Posted: 27 Jul 2012, 16:45
by bms
bigj2552;50084 wrote:thanks paul....that aint even the work space lol......thats over the other side of the room :tongue:
anyone ?
You don't print onto the flex or vinyl. These are single coloured items which you cut only.
You can buy other materials that you print onto via the Cameo and the load into the Cameo and these will be A4 sheets. The image must be in the Cameo software with cut lines set and then printed. For subli dark you would need to use PowerDriver (not available for Brother) to ensure correct colour management. Other materials could be colour laser vinyl or printable flex (not sublimation inks, but Epson durabrite) or OBM for colour laser (these are just examples).
Posted: 27 Jul 2012, 17:38
by bigj2552
thanks martin......finally got it to cut properly.......
now the vinyl i bought from you martin....the normal stuff......when i print this using the cut mat - when i apply some sticky tape to take it off the cutting matt - is there ment to be a sticky residue left on the cutting mat ?.....just wanted to print company name out and stick it to the front of the cameo for a test......it dont go on......anything to do with the sticky crap left on the cutting mat by any chance ?
or is it the wrong stuff i got ?
and......
thats anything else finished for tonight anyway.....WHY ??
thats the last bloody time that ******* wireless keyboard cuts out on me again....it just got terminated :mad:.
Using my laptop downstairs now and off to look at ebuyer for NEW WIRED keyboard :rolleyes:
The Y - W - S - T and the other letters went flying around the room.....ah well...
[ATTACH=CONFIG]1098[/ATTACH]
Posted: 27 Jul 2012, 18:52
by accdave
bigj2552;50094 wrote:thanks martin......finally got it to cut properly.......
and......
You don't use the cutting mat for flex/vinyl
Posted: 27 Jul 2012, 19:04
by bms
and......
Sorry, I don't know what you have got, but I presume it is flex, not vinyl. Flex is heat pressed onto garments. Vinyl is sticky backed for windows etc. We have discontinued vinyl so I presume you have flex unless you are using another suppliers vinyl.
Posted: 27 Jul 2012, 19:45
by bigj2552
bms;50098 wrote:Sorry, I don't know what you have got, but I presume it is flex, not vinyl. Flex is heat pressed onto garments. Vinyl is sticky backed for windows etc. We have discontinued vinyl so I presume you have flex unless you are using another suppliers vinyl.
now i know it was time to call it a day martin.....its flex bud.....:redface:
will start again tomorrow lol.....give it a break for today
still learning about this side of things......:redface:
so whats the stuff i,m thinking about then ?.....the vinyl stuff that can go on without heatpressing ?
Posted: 27 Jul 2012, 19:49
by bigj2552
accdave;50097 wrote:You don't use the cutting mat for flex/vinyl
i seen it used on youtube bud.....many times :confused:
Posted: 27 Jul 2012, 20:16
by accdave
bigj2552;50101 wrote:i seen it used on youtube bud.....many times :confused:
Never used one in 4 years of doing this :biggrin:
Posted: 27 Jul 2012, 20:29
by bigj2552
accdave;50102 wrote:Never used one in 4 years of doing this :biggrin:
think a need a beer lol
Posted: 27 Jul 2012, 20:34
by bms
That's called... Wait for it... Vinyl :-)
