A2 or larger
Re: A2 or larger
Thanks! Are you on p&p ??
- Alastair@Xpres
Re: A2 or larger
Hello Paul we won't be at P&P but our office is not too far away and we are running an open house event at the same time if you want to pop in to our extensive new showroom and have a look. I have posted the details below just in case this is of interest to you.
Have an enjoyable day
[CENTER]Xpres Sublimation [/CENTER]
[CENTER]Powering Personalisation
http://www.xpres.co.uk/c-41-sublimation-xpres.aspx?
Email me on alastair.palethorpe@xpres.co.uk for equipment advice or quotes
Re: A2 or larger
hi, i'm new member here. i'm interesting for large format printing. i wont to know, witch printers is good for canvas printing. i make a sublimation printing at this moment, but i wont to make a canvas too. witch ink i need to use for this? witch material for canvas i need? i founded something about pigment printing, but not a lot. i need to understand full process of this. what ewer i can use? i mean witch technology? how its working? do i need fix the color after printing? expect sublimation, because i dont wont to buy large format heat press machine. or its the other way how i can transfer the color from paper to polyester, mug...with pigment ink?
thanks,
Marek
thanks,
Marek
Re: A2 or larger
have 9600 refillable cartridges? can i use one printer for pigment, sublimation and chromablast printing, just change the cartridges?
Re: A2 or larger
Hi Marek, please be careful when replying to threads as some of these are quite old. Also, you are replying to different threads with the same questions, you really need to start a new thread to get the information you need and to help save further future confusion
Re: A2 or larger
why everybody use epson printers?9600, 7600. on ebay is a lot of hp large format printers? why is epson better?
Marek
Marek
Re: A2 or larger
HP printers use heat in the print head, which will give bad results if you try putting sublimation inks in, whereas Epsons don't.
Re: A2 or larger
can u answer me this question please?
can i use one printer for pigment, sublimation and chromablast printing, just change the cartridges? i mean epson 9600
