Badge Presses
Discuss other print methods.
logobear
Re: Badge Presses
Post by logobear »
thinner paper and normal works best.
edwardsmedia
Re: Badge Presses
Post by edwardsmedia »
Very nice! I have been using 80gsm paper (120gsm didn't work too good) + Inkjet currently, However will try some 100gsm in a few days... looking at getting a laser printer if i'm still not keen on the quality of print.
edwardsmedia
Re: Badge Presses
When you say normal works best Logobear are you referring to normal standard paper or a normal printer as in an inkjet? Thanks
Reg
Re: Badge Presses
Post by Reg »
My press recommends 100 gsm paper but I get good results with 80 gsm so I stick with it
John G
Re: Badge Presses
Post by John G »
80gsm copy paper using both inkjet and laser - both work fine through my badge presses.
wayupnorth
Re: Badge Presses
Post by wayupnorth »
Epson bright white inkjet sheets, 90gsm. I also use pre cut paper sheets from Badgematic and laser, sizes are not universal so check diameter(s) if you buy from them.
Re: Badge Presses
I found normal paper didn't give as sharp or colourful a print as thin photo glossy or brochure paper.
John G
Re: Badge Presses
Post by John G »
If I'm doing hundreds/thousands, it'll be the laser printer for speed - for a few off, my Ricoh does the job. I've found little difference in print quality, but that could be due to the gel inks and instant drying!
