BMS Website - Revamp & Comments
Re: BMS Website - Revamp & Comments
LOL thanks
One more thing, it might be an idea to mention how much loyalty points are worth as at the moment it doesn't tell you.
As I say, just a thought
bms;17249 wrote:Should have been left! Now changed - I blame AdamB. He had his arrow the wrong way round for AGES and this made me get ny left and right muddle up!!!
Thanks - everyone blame me (he says with a childs voice!).
Any chance of getting some images up of the BMS Team Martin?
It'll be good to see who we actually deal with .................. and then we could multi-task and throw darts in yours when items are out of stock (boom boom! - AdamB 1 - Martin 0)
Yes I need to create a graphic for that. Currently £1 = 1 point. You need 100+ points to be able to redeem them and each point is worth 1p.
We can change point values per £ spend and change the redemption value of points accumulated. This gives the opportunity for promotional events.
Do we need to register as a new account with it being a new platform?
It does look a nicer, clearer set-up. Only just starting to look but I notice the drop down menu overlaps the side of my screen on the Sublimation option so I can read/click the left hand column. The joys of launching a new website
So the loyalty scheme is 1% (£1 back for every £100 spent), then?bms;17254 wrote:Yes I need to create a graphic for that. Currently £1 = 1 point. You need 100+ points to be able to redeem them and each point is worth 1p.
I'm not entirely convinced that this will change anyone's spending habits or encourage anyone to be more "loyal" than they already are, but every little helps.
Andrew;17256 wrote:It does look a nicer, clearer set-up. Only just starting to look but I notice the drop down menu overlaps the side of my screen on the Sublimation option so I can read/click the left hand column. The joys of launching a new website
I'm noticing the same thing. The left side of the Sublimation menu is off the screen and I can't select it.
On my netbook, the drop-downs are even worse because I can't see the bottom of them either.
Just registered, looks good - much better than the last site. If using google chrome the site is a little messed up if you hover the mouse over the sublimation tab, but then again, its hard to get a site perfect in all browsers.
Penny per £ loyalty is the same as Tesco but they sometimes offer double points and also 1 free extra point for every £2 spent on a Tesco visa card. As JSR so rightly said "Every little helps".
Cheers John
Cheers John
One other question. Can I change my password to something more memorable? unu34u7hyt54n just doesn't quite stick in my mind.
I was going to ask the same thing .................. so do we all know your password now Andrew?Andrew;17265 wrote:One other question. Can I change my password to something more memorable? unu34u7hyt54n just doesn't quite stick in my mind.
