Nas
Has thanked: 13 times
Been thanked: 12 times
Re: Nas
Been looking at the Synology units which do look good but I'm getting the feeling the software won't be as user friendly, they seem to concentrate on the hardware in write ups but not found much about the software. Deffo using Red drives and will probably just get pre-built as this seems a better option. The WD software looks really good but I'm a little concerned over previous comments, all be it on older units :-)
Will be used to backup several PC's off site, I appreciate speed issues with this but not masses of data once initial backups are complete and hopefully it will be incremental thereafter.
edit: I was looking at an add on Synology unit hence no software discussion doh :-(
spongerobinson
Re: Nas
Post by spongerobinson »
Justin;88819 wrote:Will be used to backup several PC's off site
Off site as in on a different network altogether, and accessed through the internet?
Re: Nas
Yes, currently using Crashplan for this but would like to use the nas to replace this function, just need a backup from each pc.
spongerobinson
Re: Nas
I would be interested to know how you get on with this if you do go ahead with it. It might not be too bad if you've got a decent upload speed on both internet connections, and your only backing up relatively small files?
I know for the file sizes I'd be looking to backup, offsite would not be feasible with our upload speed.
