Page 4 of 5
Re: free acrylic block from bms
Posted: 13 Dec 2011, 19:03
by bms
What did you do to this Paul!!
Posted: 13 Dec 2011, 19:29
by mrs maggot
how weird, it looks as if the image has stretched and cracked - ive not pressed mine yet
Posted: 13 Dec 2011, 20:23
by Paul
bms;34841 wrote:What did you do to this Paul!!
fallowed the sticker on the plastic bag
mrs maggot;34842 wrote:how weird, it looks as if the image has stretched and cracked - ive not pressed mine yet
this is exactly what happened! picture look lovely (in real not on photo
) only thing is this crack on coating...
Posted: 13 Dec 2011, 23:38
by JSR
I've not had chance to try mine out yet (priorities, priorities... :biggrin:), but I'll post when I do.
Posted: 14 Dec 2011, 00:46
by Paul
I think temp is rigjt. But time is much to long...
Posted: 14 Dec 2011, 07:47
by bms
Very wired. Is your temp correct on your heat press - can you check with an infrared thermometer? Wouldn't have put this down to length of time as I've seen these pressed for longer. More likely is pressure/ heat I think (extremes rather than just a little bit).
Posted: 14 Dec 2011, 08:44
by Paul
I dont have infrared termometer. but all things i press are perfect! never burned etc... I also press garment film and this is great too. so cant be to hot....
Posted: 15 Dec 2011, 13:40
by JSR
I've just printed mine, and it's printed just fine - except for the Xpres paper sticking to the back (like glass coasters used to do with TruPix paper).
Looks very nice. I'll have to put some thought into stocking some after Christmas. Just wish the price for the blank wasn't so ridiculously high.
Posted: 15 Dec 2011, 18:14
by bms
Did you peal the paper away whilst it was hot? The backing is mildly adhesive when hot.
Posted: 15 Dec 2011, 22:34
by JSR
bms;34943 wrote:Did you peal the paper away whilst it was hot? The backing is mildly adhesive when hot.
Mildly adhesive? It stuck to my greaseproof paper during the warm-up phase..! :biggrin: :biggrin:
I started peeling right away. The paper at the edges of the block came away easily. It's only in the middle that it clung on for dear life. A similar thing used to happen with glass coasters/placemats that had a similar white backing. The problem disappeared when I switched from TruPix to TexPrint paper, so I'll try TexPrint next time I print up one of these.
On the plus side, though, the white backing does the job it should do here. Unlike those glass placemats I mentioned before, the ink goes through the white backing properly - giving a nice vibrant image through the acrylic, and not much colour left on the back as it should be. So that's good news anyway.
I just need to go rob a bank now, so I can afford to buy in some of the blanks... where's me balaclava?
